View topology message status to view the interconnections between Layer 2 devices in a network.
- Select Topology.
- Select the Topology Table tab.
Topology Table Field Descriptions
Use the data in the following table to use the Topology Table tab.
Name |
Description |
Slot |
Specifies the slot number in the chassis that received the topology message. |
Port |
Specifies the port that received the topology message. |
SubPort |
Specifies the channel of a channelized 40 Gbps port that received the topology message. |
IpAddr |
Specifies the IP address of the sender of the topology message. |
SegId (RemPort) |
Specifies the segment identifier of the segment from which the remote agent sent the topology message. This value is extracted from the message. |
MacAddr |
Specifies the MAC address of the sender of the topology message. |
ChassisType |
Specifies the chassis type of the device that sent the topology message. |
BkplType |
Specifies the backplane type of the device that sent the topology message. |
LocalSeg |
Indicates if the sender of the topology message is on the same Ethernet segment as the reporting agent. |
CurState |
Specifies the current state of the sender of the topology message. The choices are
